Lots of misc first gen parts for sale, axle and brake parts, glass body etc
All Parts are from 1989 - 1993 Cummins Diesel Dodge trucks, Please call/text to (630)254-29six five can text pics, make offers thanks
Brand new external lockout hubs, branded as B&M but look identical to Selectro hubs, For Dana 60 or dana 61, 30 spline(stock outer spline count), new in box, new old stock $75 35 spline open carrier from a 3.54 Dana 60 front $20 3.54 front ring and pinion from Dana 60 $80 32 spline Open Carrier From a 3.54 Dana 70U, $20 Dana power lock for dana 70, just the case halves with abs tone ring and bolts. A hard parts rebuild kit and clutches will complete it. Good shape. $80 Single rear wheel hubs from a 1991-93 Dana 70u, with brake drums and wheel studs, $60 each Brand new in box pair of Bendix rear drums for one ton/heavy 3/4 ton Dana 70. 12"x3" $90/pair Drum brake hardware kit, new $5 Pair of new parking brake cables for the inside of the drums, these do not usually come in hardware kits $5 Misc starwheel adjusters, front and rear axle hardware etc $call 32 spline axle shafts from a Single rear wheel Dana 70U, $15 ea 4x4 steering boxes with pitman arms, $30 ea Fuel gauge sending unit $20 Throttle cable $40 Cruise control actuator with cable $30 Fixed rear cab glass, might have been from a Club Cab, not sure if it makes a difference, with gasket, $10 Door vent window with latch, passenger side only, $20 Cab clearance light set with harness and gaskets $80 Wiper motor, $10 Blower motor, $10 Power window and lock switches, $5 each, tan or spice bezels $10 ea Cargo light switch $5 Information center for diesel has wait to start lights etc $20 91-93 Black grill inserts $10 each 91-93 Parking lights $10 each 91-93 headlight bezels $5 Gauge cluster, broken odometer gear in speedometer but the rest are there in the housing $20 Steering column plastic $10 Gray plastic trim for bucket seats $10 Plastic windshield washer tank, no pump, $10, with pump $20 Coolant overflow tank $15 Wiper arms $10 ea side or 2 for $15 Wiper linkage that goes under cowl $15 Air box, 1989-92 style, box and lid, $10 Any wiring harness from a 93 5 speed Club Cab excluding under the hood, also have a 92 underhood harness, and harness that extends the length of the truck on the chassis, I have many pieces of harnesses, and a 1990 gas club cab harness $call 1990 Diesel engine bay harness $120 engine harness $75 Front bumpstops/shock mount brackets $10 ea or $15/pair Front 4x4 swaybars with links and mounts $65 each Dana 60 front spring plates $50/pair New aftermarket passenger side front fender, still has stickers on it $90 Factory replacement drivers side rocker panel $80 New in box diamond plate bed rail protectors for 8' bed, $60 Diamond plate full tailgate protector, great shape, not made anymore, $100 Stock steel 16x6 wheels, $70 for the set of four Dog dish hub cap for rear, $15 Passenger side manual chrome exterior mirror $30 Power Ram 250 Cummins Turbo Diesel emblems, 1991-93 style, $35 each Power Ram 350 Cummins Turbo Diesel emblem $55 Battery tray with brace and hardware, not rusty, $20 Fan shroud for non Intercooled truck $90 Various stock clutches and flywheels for sale, $call Fisher minute mount mounting plates push plates. These bolt to frame and the minute mount plow mounts to them. $275 Reese 45005 class 5 hitch never used $130 Draw-tite class 4 hitch some rust $60 |
Can you edit posts? B&M hubs, non ic fan shroud and clearance lights sold.
You can edit but only for a short period of time....clearly you past that point.
I need grill parts for a 91 w250,the headlight bezels ,grill inserts, turn signals ,I also need drivers door and fender and window motors if you have any of these. Are you setup for paypal and what the cost is with shipping to 30904 .
thanks ,Reggie |
Originally Posted by tatsr2
(Post 3331085)
thanks ,Reggie |
