Mark this thread as Unsold
Engine & Drivetrain 1st gen parts '89-'93…about anything.
#211
Sorry Jungle.
I have been stupid busy the past 6 weeks trying to get my projects done in my small windows of free time.
I don't believe I have a cruise 88/89 steering column with a good cruise stalk. If I find something I will PM you.
#214
PM sent to AJ
#216
Oliver, I sent you a PM. Thanks!
#218
I know I would have the earlier NON intercooled fan pulleys.
I might have an intercooled one ['91.5-'93] left on the shelf as well.
#219
Oliver,
I PM’d you a few days ago in response to your post on my thread regarding a Instrument Panel Cluster housing. Did you get my PM?
Then I found this thread in the Classified Forum so I thought I’d post a request here.
I need the cluster, but I also need some additional parts for a first gen.
The Electronic Temperature Cycling Switch for the A/C .
P/N- 56005783 –
This switch mounts on the A/C line bracket in front of the Evaporator/Heater housing. It has a thermo probe that slips into the A/C evaporator suction Pipe.
Oil Filler Tube. P/N- 04429611 –
This is the vertical tube on the front of the engine where you add oil. I need only this tube, but could use the cap also. Mine is kind of beat up.
If you want to sell the tube as an assembly with the connector that attaches to the timing cover, I’d buy it that way.
At the risk of being repetitive:
Housing for the instrument cluster. P/N- 56003420 –
Made of white plastic, it contains the speedometer and other instruments. It mounts to the Dash with 5 screws. On ours, the three screw holes at the top front are broken off. I need a part with good mounting holes and tabs.
The housing we need is for the 1990 to 1993 trucks that have the electronic speedometer and instruments, NOT the cable driven speedo with the 12V/constant voltage controlled instruments.
All our instruments are good, so we only need the housing. However, I you want to sell the complete cluster, we would buy that.
Thanks, Hoping to hear from you,
Jack Dancoe
P/N- 56005783 –
Jack Dancoe
#220
PM sent to Jack.
Thanks
Thanks
#221
Would you happen to have a complete 518/205 wiring harness in good shape? Darn squire got to mine.
#222
PM sent to cougar on the harness I have in the shop.
#223
Anyone need any hard to find parts to fix up their old 1st gen.?
#225
PM sent to Hemi Cat
