Mark this thread as Unsold
Truck For Sale 1993 4x4 ext cab
1993 4x4 ext cab
SOLD
1993 Dodge 4x4 W250 Cummins 5.9 diesel intercooled automatic transmission with 269,000 miles. I am the second owner of the truck. I purchased it in 1997 with 60,000 miles. Below is a list of all the upgrades I have done on the truck over the past 20 years. I am selling the truck and camper together, if you would like just the camper that can be purchased separately for $2000.00, but I will not sell just the truck without the camper. This truck has some surface scars due to the 22 years of use, but the foundation of the truck is strong and reliable. If you are a true Dodge 1st Gen aficionado, you will now what all these upgrades are about. If you are not look them up on https://www.dieseltruckresource.com/forums/. I will not answer questions about the upgrades. The price for the truck and camper is 10,000 firm I will not move on this price. I will just keep the truck and continue to use it.
1. New Tires and brakes 2000 miles ago
2. 1 ton rear brake drums/shoes and wheel cylinders
3. RWAL bypassed
4. New E brake cables
5. New Master cylinder
6. New front springs from https://customsuspension.com
7. Rear Airbags
8. TPS bypassed with potentiometer
9. Red Head Steering box
10. Borgenson steering shaft
11. Custom steering box mounting plate
https://autofab.com/i-22828661-1972-...g-bracket.html
12. New radiator/Thermostat/transmission cooling lines
13. Larger Fuel injectors (40HP increase)
14. Banks air intake
15. Banks exhaust
16. Electric trailer brake controller
17. Class 5 hitch with extender
18. Lumber rack
19. Raider fiberglass Shell
20 Bilstein shocks approx. 4000 miles ago
Camper 1991 10 ½ foot Northland Polar. Everything works. There was a leak in the ceiling that has been repaired many years ago and is still water tight. All hydraulic jacks work. 50 watt solar panel with a new charge controller. Coleman awning, 2 propane tanks, outside shower, roof rack, roof top cargo box. I have owned both the camper and truck for 22 years and have used it. Like I said there are some battle scars, but everything works, and the truck is solid. I have religiously serviced the transmission every 20,000 miles, oil changes every 5,000. I would no hesitate to take this truck on a long-distance trip tomorrow. Truck with the camper gets 14mpg. Truck alone and empty at 60 MPH gets 18 MPG.
This is located in South Lake Tahoe Ca, Contact jeffdavies500@gmail.com
