fuel shut off solenoid
Old Feb 1, 2007 | 06:45 PM
judge88's Avatar
can someone point me in the direction as to where the solenoid is ?. truck will run but die within a couple of seconds. or will not start at all. cracked the fuel lines and getting some fuel but not alot. under 100,00 miles so i dont think its the ip.
Old Feb 1, 2007 | 07:55 PM
chop342's Avatar
From: Climax, MI (between battlecreek and kalamazoo)
Are you asking on a 12v or on a common rail? your sig shows a common rail and that doesn't have a fuel shut off solenoid per say.
Old Feb 1, 2007 | 09:13 PM
judge88's Avatar
sorry,
just bought a 96 12 valve. its for that
Old Feb 1, 2007 | 10:16 PM
65fury's Avatar
the shut off solenoid is near the back of the pump, it has a boot covering a shaft that pulls the fuel lever up and down, when you pop the hood stand on the driverside of the truck, staring at the side of the engine where the injector pump is you will see near the back of the pump on the side of the pump a solenoid with a wires coming out of it (only electrical thing on the pump) the wires probably have a plastic cover on them. heres a pic, the solenoid has the blue plastic wire shielding coming off it. (lever in up position is run, down is off)
https://www.dieseltruckresource.com/...e_pics_046.jpg
jason
Old Feb 2, 2007 | 04:34 PM
judge88's Avatar
thanks for the replys. i found the soleniod and it is bad. held the plunger up and she ran fine. let it go and it died. thanks again for the help.
Old Feb 2, 2007 | 05:39 PM
patdaly's Avatar
Isnt there also a relay that goes bad more often than the Solenoid?
I think I would verify it being bad before spending the money.
Old Feb 2, 2007 | 06:54 PM
infidel's Avatar
Look for a bad relay and the blue wire at your driver's side battery for corrosion first.
The solenoid rarely goes bad, you will be wasting money to replace it, lots of it.
Old Feb 3, 2007 | 12:25 AM
doodah's Avatar
if you take it off and replace it, send it to me, Ill pay shipping, I want to do some measuring off of it, as I do not have 1 on my truck to measure!, my shutoff solinoid has ben MIA!!, replaced with a spring and kickdown cable....
Old Feb 3, 2007 | 09:48 AM
jester1542's Avatar
The solenoid uses two voltage sources. One when the engine is cranking and one to keep the solenoid in a run condition. The diagram below is a summary of the wiring diagrams in the 97 service manual. Your 96 should be very similar.
Smokkin
Apr 4, 2012 02:43 PM
dkimmel
Jan 3, 2011 10:54 PM
randyswelding
Feb 9, 2009 10:40 PM
skywalker175
May 13, 2003 02:37 PM
doomgaze
Dec 12, 2002 05:18 PM
