wont start easy
Old Jan 29, 2004 | 08:57 PM
loch's Avatar
wont start easy
hello just thought id ask, yesterday i stopped and got fuel at a fina station.after paying for the fuel it was hard to start it had to wind up,and it now has no power, takes over a half mile get to 55. It seems to be bogging down very badly,but it idles just fine. It is a 95 ctd and has never given any problems at all till now. Any ideas on things i can check to start eliminating what can cause this ,,,thanks,,,
Old Jan 29, 2004 | 09:28 PM
moparguy's Avatar
First thing I'd do is smell the fuel and make sure it didn't have a gasoline odor. If OK, I'd change the fuel filter and inspect the old one for water or slime from the stations tank.
Sure sounds like a clogged filter.
Good luck, RJR
Old Jan 29, 2004 | 11:05 PM
Dr. Evil's Avatar
Have the rubber fuel lines ever been replaced.....?? Could be air getting into the fuel system....
Old Jan 30, 2004 | 08:31 AM
kandgo's Avatar
Bad fuel? Fuel filter? Fuel heater pre screen? Fuel lines? I would start with them as suggested above, Goodluck, and let us know, Rick
Old Jan 30, 2004 | 09:21 AM
Dr. Evil's Avatar
very good point....if you havent replaced your fuel filter pre-filter, it could be plugged...
http://www.dodgeram.org/tech/dsl/fil...filt_clean.htm
Old Jan 30, 2004 | 07:37 PM
loch's Avatar
thing is i drove it to the store about a mile down the road it went to normal ran perfect till i got home,started it up about an hour later went right back to doing it. i have changed the filter and the rubber lines and checked intercooler boots to make sure they were not loose,and i filled up both trucks at same time the other ones fine,so i doubt its bad fuel.
Old Jan 30, 2004 | 09:53 PM
infidel's Avatar
Check the pre-filter before doing anything else
Old Jan 30, 2004 | 10:06 PM
darloa's Avatar
I would also check to see if the fuel shut off solenoid is opening all the way, maybe hanging up, not allowing enough fuel to flow. Darl
Old Jan 31, 2004 | 08:15 AM
Smokee's Avatar
...and finally, make sure that the accelerator cable is in good shape. they do stretch.
Old Jan 31, 2004 | 07:59 PM
loch's Avatar
thanks guys it was the shut off valve not going all the way,
rustydeeretech
Jun 16, 2010 09:41 AM
Stroked-Z
Oct 4, 2008 11:28 AM
mullishacrew
Sep 6, 2008 01:12 AM
qcstunter
Jan 9, 2007 04:10 PM
trailblazenyj
Mar 14, 2003 11:18 PM
