wont run unless at 45* timing
Old 10-15-2007, 09:31 PM
97ramctd's Avatar
Well long story short i put a newer motor in my truck, installed my pump on it (everything locked in), it wouldn't even start. So we advanced it a little bit (so we thought) and it ran great, but over the past i'd say 4 months or so, it has blown 4 head gaskets. So we assumed it had to be timing causing this. We got a timing kit and checked the timing found it was right at 45*. We then dropped her down to 16* and now all it does is pop and crack when you rev it up. Thought maybe to much fuel so i backed the plate and the afc all the way back, no difference at all..
It ran great at 45* but at 16* runs like crap? Any ideas?
Old 10-15-2007, 11:07 PM
Tate's Avatar
Right timing chart for the pump? Is the engine at true TDC? Have you tried timing it to somewhere between 16 and 45?
Old 10-15-2007, 11:16 PM
97ramctd's Avatar
motor has no data plate.
Was using the timing pin below the pump, gonna try the drop valve method tomorrow.
The pump is a 913 if it helps anyone.
Old 10-15-2007, 11:22 PM
Tate's Avatar
16 degrees is 5.6mm then, yes? Whats your lift on 45 degrees? Drop valve would be best, but I can't see the timing pin being out that far.
Old 10-15-2007, 11:36 PM
97ramctd's Avatar
yes that is what we were going by.... IIRC it was up around 12. or 13. something i don't remember i didn't figure it, just glanced at the figures
Thats gonna be our next attempt to see how it goes.
Like i said earlier, when we first installed the pump on this motor we locked the pump then locked the timing pin, installed and it wouldn't even attempt to start so i think something has to be off somewhere.
Old 10-16-2007, 10:24 PM
dodgeman01's Avatar
I don't have a timing kit but What I have always done is just pull the pump gear and rotate the engine by 1/4 until it runs the way you want. then if you have a kit check it and see what it says. I change timing so much on my truck due to cold starts and pulling season that I marked TDC on the balancer and a pointer on the bottom of the oil pan. then I marked where It runs best in the winter. Many engines run different even though they are the same cpl #'s its not a big deal if you are just running on the street but when it comes to pulling and trying to get all the HP you can I have never had 2 engines runs the same due to injectors wan injector washer thickness # of miles on the motor. how many rpms the gsk is which DV's the guy is running. it all makes a difference which all adds up. It can be 3* or 10*
Thats my .02$
DM01
Old 10-16-2007, 10:50 PM
dezlsmkr's Avatar
Its actually at 35.5 its 9.6mm of lift.
Mountaineer
10-04-2011 07:00 PM
Stroked-Z
10-04-2008 11:28 AM
marc eber
06-12-2007 09:34 PM
Dodge2003
05-11-2007 08:05 AM
DesertTRD
12-06-2002 01:57 PM
Quick Reply: wont run unless at 45* timing
