wild ride
Old Dec 23, 2006 | 10:14 AM
brooks829's Avatar
wild ride
I was driving my 97 2500 4wd around 40mph hit a small bump in the road and the front end started shaking like the tire blew out, or like the tires were on a cam. I stopped and check the front end everything looked fine, drove ok after and still does.
I drove my friends 95 1500, hit a bump about the same speed and same thing as mine, shook crazy. I am leaning towards a bad strut or track bar.
anythoughts would help,
Thanks,
brooks
Old Dec 23, 2006 | 10:28 AM
ratsun's Avatar
It sounds like you have just experienced Death Wobble
If you do a search on it you will find enough reading to keep you busy till the new year.
Old Dec 23, 2006 | 02:43 PM
xtoyz17's Avatar
Would that be the same as when I'm stopping and suddenly (every one in awhile), the car just starts shaking like it's gonna fall apart?
Old Dec 23, 2006 | 08:21 PM
Racer9's Avatar
Ummm, car???
Yeah, same thing.
Old Dec 23, 2006 | 10:57 PM
Buckshotram's Avatar
i second the death wobble, check your trackbar there are quite a few aftermarket options.
Old Dec 23, 2006 | 11:53 PM
xtoyz17's Avatar
My bad. Used to driving the taurus...
Old Dec 24, 2006 | 08:03 AM
Racer9's Avatar
The front end needs to be gone over thoroughly. Have someone rock the steering wheel back and forth while you look over the suspension. Track bar, tie-rods, ball joints, stabilizer, steering box, heck it could be as simple as shocks, or a bent/bad tire/wheel.
If everything is tight, an alignment is in order, set the caster at maximum, that should help.
Rushford
23
Aug 26, 2007 07:21 PM
Deezle98
May 11, 2006 01:17 PM
12valve@heart
Jan 27, 2004 01:25 AM
95ramtough
18
Feb 23, 2003 08:46 AM
Wade
Nov 12, 2002 12:56 PM
