Whats wrong?
Old Oct 5, 2009 | 11:16 AM
cab9379's Avatar
Whats wrong?
Ok I get up this morning with frost on the ground and my truck wouldnt even crank over, so I have my buddy come over to take me to work and just out of curiosity I had him hook it up to his jumper cables it wasnt 3 minutes and the truck started like nothing was wrong. I just went out on lunch break to see if it would start and it started fine can someone help me diagnose the problem. Thank you.
Old Oct 5, 2009 | 12:19 PM
patdaly's Avatar
Probably starter contacts.
Old Oct 5, 2009 | 01:41 PM
FlaCracker's Avatar
Could be the starter solenoid. you may have a dead-spot on the contact washer.
Old Oct 5, 2009 | 09:40 PM
Yellow Yota's Avatar
Here you go:
http://www.fostertruck.com/dodge/
Only hard part is getting the top bolt of the starter loose. Other than that, it's a cake walk.
Old Oct 6, 2009 | 04:00 AM
NEFF12V's Avatar
Yeah right, all three bolts are equally hard!
I just spent all morning trying to get them loose, then I sat back and had a beer and they all came right off.
oh yeah, lots of WD40 and an impact wrench with a universal joint (not recommended)
Old Oct 6, 2009 | 06:51 AM
RPegram's Avatar
Sounds like batteries were dead or weak. Jump start + crank = weak or dead batteries.
While you drove truck to work, alternator did what it is designed to do - charge the batteries. If you did not leave something on, I would change both batteries. Cold + dead battery = bad battery.
Old Oct 9, 2009 | 10:30 PM
dieselman97's Avatar
easy way i have found to get the starter bolts out is a 10mm ratchet wrench. worth the money if you just buy it separate!! MAKE sure it is 12 pt. though!!!
Old Oct 10, 2009 | 05:02 AM
sewman's Avatar
Sounds like batteries to me too,as they get worse they'll hold a charge shorter & shorter.
Old Oct 10, 2009 | 07:59 AM
G1625S's Avatar
Heh, Yeah, those things mess with you, eh? Stings a little bit
Old Oct 10, 2009 | 04:13 PM
Tate's Avatar
10mm combo wrench and a medium ball peen hammer is what I use. Beats trying to get a long setup like a ratchet and extension, or impact extension in that tight place.
Old Oct 10, 2009 | 06:24 PM
infidel's Avatar
All of my universals are in pieces from trying to use them with an impact.
Luckily none of the pieces are in my head.
Old Oct 10, 2009 | 07:32 PM
dieselfuelonly's Avatar
DTR question asker
I used a 10mm 12pt combo wrench, took a piece of wood and cut a little notch in it then used it to push against the wrench with a floor jack on the other side of the piece of wood. Broke it loose really easily, but I sure wish it was a ratcheting one because removing it still took a long time .
Old Oct 11, 2009 | 04:00 PM
Tate's Avatar
Once mine were cracked loose, all came out by finger.
Old Oct 11, 2009 | 05:00 PM
1-5-3-6-2-4's Avatar
If you had impact universal joints that wouldn't happen.
my snap-on 1/2" impact universal has seen abuse and some from the 3/4" gun. the starter bolts on an AC Delco MT42 that have been on a highway tractor for some years are usually no cake walk to get out. have to use the universal sometimes. Its never given even a wimper.
Old Oct 11, 2009 | 09:32 PM
sdseva's Avatar
i 2nd that. i just did mine a couple weeks ago. remove the blow-by tube then all you need is an extension as long as the starter on a ratchet to get a good straight approach on that little top booger bolt. its all gravity after that, its a heavy one. just a note, i got those contacts and the plunger for 15 dollars so shop around. and another note, the contacts didnt fix my problem good luck
