What's so special about the injector pump nut/washer? Replacement?
I saw in a post on here somewhere about a replacement injector pump nut, I can't find the thread now though. It was a deeper nut...anyone know what I'm talking about or where to find it?
Also, my washer is flat, I need a replacement. What kind of metal does it have to be? I called the dealer, they want $21 for the nut, $5 for the washer! If I know what kind of steel/metal I need I can probably get one from the local bolt manufacturing joint here instead, unless there is something special about them? Plus it won't be in until next week. Thanks... |
The washer is slightly concave so that it acts like a lock washer.
Not real sure you'll be able to find one easily elsewhere. I've aways reused the old nut. |
When I did my timing I changed both my nut and washer, although I could have reused the nut. Got them from Cummins, here are the part numbers:
Nut: Cummins 3920921 Washer: Cummins 3920922 I think the washers are just a few dollars. |
I took a quick look at the washer, it looked like an actual lock washer, unless I'm mistaken...?
So it's not just a regular lock-washer then eh...bummer. I have a couple Cummins places around I'll see if they have or can get them. Thanks for the part #'s!!! |
This was originaly posted by "BERNER" on another thread.
Here's a photo of the nut upgrade. It's from Saskatoon Diesel Services Their part # is AT90. Price in 2002 was $14.29. |
their web site.
Originally Posted by Mcmopar
(Post 1226193)
Do you replace the washer each time?
Here's a photo of the nut. https://www.dieseltruckresource.com/...2P7100Nut2.JPG
Saskatoon Diesel told me that no washer is req'd with this nut. I think they torqued it to 180 ft-lbs. It was a while ago. They'll be able to tell you what to torque it to if you call them. |
Thanks for the pic...sure doesn't look like a washer would fit with that nut.
I called up a local Cummins dealer, part should be here tomorrow, $11.83 for the nut, $2.90 for the washer. Another dealer was similarly priced. I should probably order that big nut and have it on hand to replace some day though...but for now I just wanna get this hooptie running again. |
Originally Posted by SHARPMACHINE
(Post 1226264)
