what turbo is this?
Old May 4, 2008 | 12:07 PM
ahopper's Avatar
what turbo is this?
i am trying to figure out what size exhaust housing is on this turbo. i know the intake side is 62mm but in the exhaust inlet it says 138? Here are some #s on it
P/N 168824
MOD S300SOI8
S/N FO906
668323 DUO 430
138 -B-
055H Schwitzer
168323
699956 M6R
Can someone give some insight Please!!??
Old May 5, 2008 | 03:19 PM
ahopper's Avatar
anyone think i should mess with it? is it a s300?
Old May 5, 2008 | 03:42 PM
stock600's Avatar
My BIL has one on a 1st gen and it works great. Rec. blew a HG with it at around 48 lbs of boost. And i believe its the same center section that II and HTT uses to build all thier turbos.
Old May 6, 2008 | 02:02 PM
ahopper's Avatar
i found out that the exhaust housing does not go by ar or by a cm^2 , it has a 138 on the exhaust inlet and a 138 stamped on the outside. can anyone tell me what size in cm^2 this is?
Old May 7, 2008 | 12:58 AM
ahopper's Avatar
also if it is too big of a exhaust housing can i find a smaller one to put on it?
sorry for all the questions. just trying to find a diecent turbo that will fit in my budget
Old May 7, 2008 | 01:14 AM
Alwaysworking's Avatar
alwaysonDTR
what does the exhause outlet measure?
Old May 7, 2008 | 11:27 PM
Supa Dexta's Avatar
Hi, I just joined for this thread. I have a S362, and these are the same numbers as my center section> 699956 M6R. I run an S362 with a divided T4 .83 hotside, which is the hotside off of a 366, and from a john deere originally. My hotside is out getting ceramic coated right now, so I can't look to see what numbers were on it.
Ada381
Feb 10, 2008 07:58 AM
j
Jan 9, 2004 08:19 AM
Haulin_in_Dixie
Jul 21, 2003 11:14 AM
redram
Dec 10, 2002 09:54 AM
