what do i torque the injectors to
Old Jan 14, 2005 | 12:23 AM
halerazor's Avatar
i'm installing 370's tomorrow and wanted to know what to torque them to. they came with no instructions so help me out. where do the "c"shaped washers go and where do the rubber seals go. am i worrying too much about this or should i just pull the stock injectors out and assemble the 370's just like the stocks
Old Jan 14, 2005 | 01:14 AM
hotmopr's Avatar
The rubbers go on top of the nut. You will need a small screwdriver to get the rubber washer in the groove after they are tightened down. The c shape washers go on the small fuel line that connects the injectors to each other. It's easy to tell once you start pulling it apart. Also if you got multiple thicknesses of flat copper washers go with the thinest ones you have.
Old Jan 14, 2005 | 01:25 AM
halerazor's Avatar
what about ft/lb of torque or do i just get them in there tight
Old Jan 14, 2005 | 09:45 AM
infidel's Avatar
I'm sure there is a torque value but I've just gotten them tight.
Make sure to completely remove the injection and return lines. Bending them out of the way will make the job much harder and risks cracking the lines.
Old Jan 14, 2005 | 09:53 AM
bulthisl's Avatar
The tq. is 44 lbs.
: Eddie :
Old Jan 14, 2005 | 10:44 AM
gunracer1's Avatar
turn it till it strips, then back it off a 1/4
Old Jan 15, 2005 | 10:02 AM
Jrr's Avatar
Jrr
Dont forget to run a bore brush in the bores before installing new injectors.
Old Jan 15, 2005 | 11:00 AM
BoostdCTD's Avatar
Did you try that on your own first?
Old Jan 17, 2005 | 10:03 AM
gunracer1's Avatar
allways, that way you know you gat all it can take.
mainer
Jul 17, 2007 07:13 PM
KRB
May 20, 2007 06:20 PM
BIGOKIE
Jul 21, 2004 05:53 PM
PapaSmurf
Dec 19, 2003 02:14 PM
Davidp
Feb 1, 2003 05:49 AM
