What 3rd gauge?
Old Dec 18, 2011 | 11:22 PM
TheNeckasaurus's Avatar
Are those glassworks fenders? Or just flares? Whatever they are they look good
Old Dec 19, 2011 | 09:52 AM
infidel's Avatar
Originally Posted by MNorby
Finally got everything all mounted and plumbed and seeing only 8-9 psi at idle and around 15psi at 2500 rpm. Fuel filter replaced and strainer cleaned last month. Overflow replaced this last summer just for periodic maintenance. Will double check overflow with the squeeze return line trick tomorrow and go from there I guess.
If you are using an isolator it's most likely the problem.
Your gauge isn't reading right.
Swap the isolator for a coupling.
Old Dec 19, 2011 | 02:46 PM
MNorby's Avatar
Nope, just flairs.
It is direct. Needle valve at banjo bolt then straight to gauge.
anonymous_1
13
Apr 30, 2020 04:29 PM
buckman361
Oct 10, 2008 11:23 PM
1qckdodge
Mar 5, 2007 09:53 AM
Bobcat698
22
Oct 14, 2006 09:12 AM
skydiver41
Jun 14, 2006 11:20 AM
