WH1C w/12cm WG ?.....
Old Feb 8, 2007 | 05:42 PM
ckt_santiago's Avatar
So I have always wondered why the snail for my intake side looked monsterous in comparison to other 2nd Gen CTD.... Well reading on a post somewhere else in here I found out that one of the updates for the early 94 model year was a 12cm waste gated exhaust housing added to the WH1C turbo.
Now for the question; I want to know if there is a 14cm waste gated housing out there for the WH1C... That and does anyone have any idea what the inducer size of the WH1C is? Maybe the HP capacity if I were to update to a 14cm housing? Even if I have to find a non WG housing and do it with a pop-off valve on the exhaust manifold (routed to the downpipe).
Old Feb 9, 2007 | 01:02 PM
1stGen545's Avatar
Yes they make a 14cm w/g $415 and non w/g $177 from Piers Diesel Research and others. will help lower EGT's on the top end. They fit the H1C, WH1C, and HX-35. Keep the WH1C down to about 30psi. any thing more and you are super heating the air and not gaining any thing but asking for the compressor to blow. I would up grade to an HX-35 has larger wheel and is good for 36psi. Or check out HTTurbo for up grades for your stock turbo.
edwinsmith
Feb 9, 2005 11:49 AM
sammy340
Oct 7, 2004 05:54 PM
Crimedog
Jun 23, 2004 09:06 PM
wannadiesel
Apr 27, 2004 06:32 PM
boostnCummins
Jul 26, 2003 03:26 PM
