-   12 Valve Engine and Drivetrain (https://www.dieseltruckresource.com/forums/12-valve-engine-drivetrain-100/)
-   -   Water pump with shroud? (https://www.dieseltruckresource.com/forums/12-valve-engine-drivetrain-100/water-pump-shroud-336821/)
BigstarATX Sep 29, 2025 07:05 PM
Has anyone ever installed a water pump with a shroud on their Cummins 5.9? My water pump dumped my coolant this morning so I picked up a water pump. The one they had in stock is a Murray WITH shroud. Has anyone ever installed one? Are there any benefits or issues with the one with the shroud around the blades? The one I got is the 5 blade. They also have a 7 blade. Can anyone tell me the differences in blade count? Thank you guys
texasprd Sep 30, 2025 04:12 PM
See if this helps: https://www.dieseltruckresource.com/...m_content=post
cougar Oct 3, 2025 03:40 PM
Yes you can, but it's kind of a maze snaking it out between the fan blades.
