water pump?
my 98 just started pouring coolant this afternoon, it happened all of the sudden.
It looks like its coming from right behind the water pump, checked the hose connection, it's tight. Is there anything aside from the pump that it could be? Or is that it, it just went all of the sudden? |
Sounds like the water pump. They're not that difficult to swap out yourself.
theres a weep hole on the bottom side of the water pump that you cant see
its the pump, super easy to replace. Mine went out last month and I lost all my water- and once the water was gone my gauge sunk over to cold!! Not good! Glad I knew better and pulled over asap, I shot the block with my IR thermometer that I carry for EGT temps, the block was at 316F [yuk] right next to the big 53 but still idled perfectly-- hope everything is ok. I will take a video of how much slop is in my old pump- doesn't even turn anymore as the blades are hitting the block casting.
Originally Posted by joem
(Post 3201974)
After that happened I had my friend tow me to my fathers house where we have a large shop and I started tearing it down to the point that I would have to replace everything (killer dowel pin and hooking the Ebrakes up to the disk axle) that I keep processioning on (see PM) I have been working 12 hour shifts at work so the truck still sits completely tore apart.
The trucks Gauge swung back and forth from ice cold to just before the red, so I think hot water was randomly splashing past the sensor. |
Originally Posted by chariotdriver
(Post 3207065)
This is a little worrisome........why wouldn't the gauge register?
Be sure to buy a good one. I bought a Napa & a Carquest both failed in 35K. Now I'am waiting for my electric pump to show up in the mail.
Electric water pump?
They're all made in China I believe.
http://www.jegs.com/images/photos/50...55-50935_4.jpg
here ya go Bill Ive never seen one before either |
