very low on power, fueling problem?
Old 09-19-2010, 07:53 PM
cmac's Avatar
Unhappy very low on power, fueling problem?
my truck lost a bunch of power, it seems to be at stock power levels. it starts and drives fine but here is what it is doing: i get one little puff of smoke if i stomp on it, and it used to smoke quite a bit all the way through the gears. it has the 3k gsk but it now shifts at about 2600 rpm's instead of 3,000-3,100 rpm's. i even took out the arm in the AFC to rule that and an air supply problem with no change in symptoms.
do you think it would be worth changing out the fuel filter even though it isnt due for a change yet? i have a gut feeling that my problem lies within the injection pump.... please let my gut be wrong...
Old 09-20-2010, 07:44 AM
patdaly's Avatar
You need to check the fuel pressures..........
Could be filter, could be overflow valve.
Old 09-20-2010, 07:57 AM
Received 2,372 Likes on 1,568 Posts
I think the same as Patdaly.
I have driven a few p-pumped motored trucks that where gutless until I threw a overflow valve at it. A plugged fuel filter would do the same.
I got my last overflow valve off E-bay for $35 I think.
Someone had the info on here at that time, about finding the e-bay guys ad.
Old 09-20-2010, 09:39 AM
infidel's Avatar
Instructions> http://www.cumminsforum.com/forum/94...-12-valve.html
Old 09-20-2010, 04:20 PM
cmac's Avatar
thanks i'll try to get to the parts store tomorrow. is it safe to run the gauge into the truck or should i mount it under the hood somewhere?
Old 09-20-2010, 04:59 PM
cmac's Avatar
also does anyone have a closeup picture of the valve or a part number, the parts stores that i've called dont seem to have a clue what a needle valve is. thanks
Old 09-20-2010, 06:40 PM
infidel's Avatar
Needle valve> http://www.grainger.com/Grainger/Nee...N31?Pid=search
I've had a fuel pressure gauge in the cab of both my trucks for over 13 years without a problem.
Old 09-21-2010, 05:19 PM
cmac's Avatar
ok i got the gauge installed and i am getting 10-11 psi at idle, it drops very little when i rev it up to 2500 rpm's like 8-9 psi. when i give the skinny pedal a push down the road the gauge reads a big fat zero. i'm guessing this means i need to change the fuel filter right?
Old 09-21-2010, 05:56 PM
nuttynotty's Avatar
So what happens when you pinch the return fuel line, if you have no fuel gauge, you need one. The fuel pressure should be around 55~60 PSI, of not I would shoot for the filter, if no change look at the lift pump.
Old 09-21-2010, 06:53 PM
infidel's Avatar
Change the fuel filter and service the prefilter.
Pinch off the return hose that passes behind the fuel filter with pliers with the engine idling.
You should see at least 60 psi on the gauge.
If you don't the lift pump is bad.
If you do and the fuel pressure is still low replace the overflow valve.
Old 09-21-2010, 08:12 PM
cmac's Avatar
thanks! i'll try to get to that tomorrow.
Old 09-24-2010, 04:49 PM
cmac's Avatar
changed the filter and it was black. the pre-filter seems to be where most of my problem came from, there was a bunch of dirt and crap in it, the screen was black and you couldnt see through it. it cleaned up pretty good though. my fuel pressure is up to 17-18 at idle and 20-22 while driving. i havent tried pinching off the return line yet. its crappy outside so i'll do that later. thanks for the help.
Old 09-24-2010, 10:55 PM
brandon mitchel's Avatar
Maybe it's the driveshaft.
Old 09-25-2010, 11:32 AM
cmac's Avatar
huh?
Old 09-25-2010, 12:04 PM
I think brandon might have had one too many on a Fri. night.
justagoodolboy
04-20-2010 08:49 AM
dieselfuelonly
06-22-2009 06:13 PM
Mosephus
07-08-2008 06:19 PM
eng208
12-07-2006 07:48 PM
Dave88LX
35
12-07-2006 05:49 PM
Quick Reply: very low on power, fueling problem?
