-   12 Valve Engine and Drivetrain (https://www.dieseltruckresource.com/forums/12-valve-engine-drivetrain-100/)
-   -   v10 to cummins swap? (https://www.dieseltruckresource.com/forums/12-valve-engine-drivetrain-100/v10-cummins-swap-173320/)
jaconst Oct 12, 2007 10:47 PM
I have a 98 3/4 ton 4x4 8.0 ltr V10 auto and I want 2 pull out the v10 at some point and get a cummins I figured a 12 valve if I can find one and I am wondering if I am getting myself into something that I can make happen or major headaches and what I need 2 get as far as do I need wwhat wiring or where I can info on doing it? any help is greatly appreciated. god bless
jaconst Oct 13, 2007 09:35 AM
I searched and can't find out if I can do this. although I did find out & realize the v10 isn't a bad motor and the mpg is about what a big v8 anyways. thanx
95black2615 Oct 13, 2007 11:08 AM
The frames are identical, so it will physical bolt right in.
ajs1995 Oct 13, 2007 11:18 AM
tranny wont hold up to the cummins although it is the same
Tate Oct 13, 2007 03:49 PM
Why's that?
jaconst Oct 14, 2007 12:17 AM
what about computer box wiring ect? I know ill have 2 get the intercooler radiator and all the intake turbo fuel lines ect.? I'm already having problems w/the tranny but I suspect its the tps? I'm gonna figure it out as soon as I can. any input u have is greatly appreciated.
~Angry Tractor~ Oct 14, 2007 05:54 AM
Why not just buy a 12v? I would imagine that by the time you have everything you need plus your investment in your truck, you could have easily bought a 12v truck and spared yourself all the headache. Just my opinion though.
logskidder Oct 14, 2007 10:33 AM
Why buy another truck??? he can do this swap for 3k if he shops around. He could put it together in a weekend if he has all the parts engine,rad,cooler,piping,boots,underhood harness,proper accesories,pcm and engine mounting hardware. Its really not alot of work.
slowflyer2112 Oct 14, 2007 01:08 PM
fuel tank and fuel management system is different, wiring is different, intake and exhaust are different.
Find a wrecked truck and start swapping.[coffee]
logskidder Oct 14, 2007 01:46 PM
Im pretty sure the tanks are the same,filler necks are different.Use the stock fuel lines....lift pump's already on the engine, intake and exhaust flavor of his choice. Sell off everything left over[guitar]
cnvrt2cummins Oct 14, 2007 03:25 PM
I am saying if you can do this for 3000.00 in a week end you must have superman helping you. I have done many conversions even though they have been on fords and chevys it will still cost more than 3000.00 My guess is no less the 4000.00 and easily 5000.00
logskidder Oct 14, 2007 08:50 PM
You may be right......where do you think the money is going to go. Superman helping ...no just my dad....he's pushing 80 so I wouldnt call him superman,he too crabby to be superman anyway. How much labor do you think should be involved in removing a front clip, removing a engine, reinstalling another engine, reinstalling front clip if everything you need to do on the job is pretty much bolt on, and your project is well researched in advanced. What do you consider a full days work??? Im just wondering incase I ever need to take on something this.
Hammily Oct 14, 2007 10:58 PM
I bought the parts truck for my Excursion for $2200.00. It had 120k. It took me a long time to put the 5.9 into the Excursion because almost nothing works without some modification. I think putting a 5.9 into a Dodge would be relatively easy.
1stGen545 Oct 14, 2007 11:08 PM
The trans is the same inside and out and has the same bell. Should be able to buy all the parts and bolt the 12 valve in. You should be able to do it for $2500- $3000 at the most including the 12Valve with the prices they want at the junk yard around here. I would do it.
96_12V Oct 15, 2007 11:56 AM
Originally Posted by logskidder (Post 1741016)
You may be right......where do you think the money is going to go. Superman helping ...no just my dad....he's pushing 80 so I wouldnt call him superman,he too crabby to be superman anyway. .
That's probably WHY he's pusing 80 and still removing/re-installing engines into veichles! :cool: All of us younger not doing this sort of thing regurally (myself included) are the ones who likely become unhealthy later in life.
As to the swap - it can be done, and as others have said it's probably not too hard. I guess what's wrong with the V-10? I understand there's quite a following to these engines as well, perhaps it would be worth researching how much you could sell it for and pick up a different unit with the Cummins already in there. Just my $.02 good luck!
