V-10 trans-cummins???
Old Jun 19, 2010 | 02:47 PM
MoparTyson's Avatar
Can I use a overdrive trans out of a 95 V-10 truck in my 1st gen cummins truck???
Which trans is this???
Old Jun 19, 2010 | 03:22 PM
1stgen lover90's Avatar
Ya I'm sure and its probably a 47rh I own a 94 v10 when it got rebuilt the Guy said its a diesel trans so ya but u need the pcm for the tranny if u get it which its on the firewall on the passenger side of the truck oh and you'll need the spacer off the back of the engine and the starter as well the one on your first Gen wont work so u need both starter and spacer of the engine but should work
Old Jun 19, 2010 | 03:31 PM
MoparTyson's Avatar
I hope so cause I can get this truck cheap!!!!
Old Jun 19, 2010 | 03:34 PM
Ya should work oh and you'll probably have to do some tranny cross member relocation and refab work on but of it's a early 95 should be a 47rh
Old Jun 19, 2010 | 07:22 PM
kensmachine's Avatar
You will need to change the governor in the transmission and the converter.to tell what transmission look at the plug in on top of the tranny just in back of the shifter if it has 3 wires going in to the tranny its the one you want. more than 3 and its 47re Ken
Old Jun 19, 2010 | 08:36 PM
MoparTyson's Avatar
I'm trying to gather parts for my conversion. My donor truck is a getrag but I want an automatic.
What else do I need to put this in my truck????
Old Jun 19, 2010 | 10:17 PM
dodgetrucker75's Avatar
the trans will bolt up to the engine no problem, the 95 should have the 47rh but you will need a cummins flywheel, the converter may work ok, but should also be from the cummins, and a cummins valve body will be nessasary to get the correct shift points, you dont need a controller to operate it, but there is a converter lockup and overdrive that is electrical, you can operate them manually if you want and there are stand alone controller avalable
Old Jun 19, 2010 | 10:22 PM
MoparTyson's Avatar
Does the V-10 have an adapter????
Old Jun 19, 2010 | 10:29 PM
nope... it is the same bellhousing, no adapters, it will bolt up
Old Jun 19, 2010 | 11:23 PM
MoparTyson's Avatar
Let me make sure I got this right. The cummins has an adapter on the back of it that works with standard or automatic transmissions??????
Old Jun 19, 2010 | 11:33 PM
yes there is a bolt on adapter on the back of the cummins,used for auto's and 5spd manuals, 6 spd is different, and no adapter at all on the v-10
Old Jun 19, 2010 | 11:41 PM
MoparTyson's Avatar
Thanks. I'll buy the truck then. Where can I find more info on the stand alone controler?
Old Jun 20, 2010 | 12:09 AM
http://www.suncoastconverters.com/do..._products.html
Old Jun 20, 2010 | 12:33 AM
BC847's Avatar
1st Generation Admin
The mechanical governor of the gasser A518 will not work in a diesel application as it allows shift-points that are way too high for the diesel. You will have to change the governor assembly (not just the weights).
Old Jun 21, 2010 | 12:28 PM
Stamey's Avatar
I asked my tranny guy this very question the other day, for my Dad's 95. He said yes, it fits fine, but you must use the diesel TC and while you don't HAVE to, you should use the diesel valve body because the shift points are different because of the different RPM where the torque peak occurs. Everything else is the same.
Chris
