Upgrade combo for best fuel milage
Originally Posted by WideOpenThrottl
cumminsdriver635, how will the auto benifit for better milage on the interstate?? does it have a higher top gear ratio than the 5spd.?
I was always under the notion that a manual driven nicely will always net better milage do to the fact that there is less power loss through the drivetrain.
tim.
tim.
I believe a manual would win stock truck vs stock truck in town. The reason i say the auto would be better for the interstate is that 4th gear in the auto's is pretty high. I can run about 75mph at 2k rpm's if i remember correctly. The overdrive ratio in the auto is 0.69:1 so it is pretty high. My truck was built for the interstate with 3:54's, and the auto In town with an auto with a good aftermarket EFFICIENT torque converter should be the same as a manual. Maybe better?? You dont lose boost on shifts, and you can freewheel more, but i dont know if that would help or hurt. Id say overall they would be pretty even in town, with the auto having a slight edge on the highway, but that is just my guess.
Eric
Originally Posted by tmacie
MnTom,
Thanks for the input, I understand differnet things for different trucks. I guess I'm looking for "Heres what happened to me when I did this"
Thanks,
Travis
Thanks,
Travis
Tom
Eric
Eric
Thanks for the info, tim.
MnTom, this is PERFECT!!!!! Exactly what I'm Looking for. It looks like you made mods, slid the plate full forward, noticed power but a drop in milage so you moved it back an got some milage back, correct? What are you getting for milage?
Travis
Travis
Well, You need to remember that this all took place about the same time fuel hit $3/gal. I went from about 16 mpg to about 19 mpg. I also have gone a little lighter on the throttle too, however, I still get going faster than when I am in my Jeep w/4.0 or Caravan w/3.3. Pulling two trailers with a CGVW of 17k+ I still manage to get 12 to 14 mpg. The best thing is taking off from a stoplight and out pulling most of the traffic without even trying! The look on some of their faces is great.
Tom
Tom
jmd4993
07-15-2013 11:02 AM
Dually Driver
13
11-13-2007 09:10 PM
Road Traveler
20
11-12-2007 01:30 PM
Capp35
06-02-2007 10:09 AM
