Turbo bark on shift into OD
I have been noticing that when I shift into OD at light to medium throttle, I get a VERY noticeable bark.
What would be the likely causes?
Shifting too hard (trans needs to be adjusted)?
Exhaust leak at the manifold to head joint (I have a small one developing)?
Doen't seem to be an issue at higher throttle positions, or if I wait til I reach about 50mph, let the boost settle and then allow it to shift.
If my converter locks up under a lot of boost, mine will bark pretty good.
I just adjusted my style a little. Either roll into it easy untill it locks and then get back in it, or keep it to the floor untill I get to speed and then let up.
Mine barks even when I leave the pedal alone. If I roll off the throttle and let it shift into OD and lock up, then I can roll back onto it with no bark.
Normal acceleration for me with a full load (17k) at half throttle will hit OD with about 25-30psi.
I really do wonder if my exhaust leak is part of the problem. That would make it easier to drop pressure on the exhaust side and slow the turbo down. I will post back here in a few weeks if I get the time to fix it.
cluckmaster
14
04-13-2007 07:07 AM
gatf4
18
05-31-2005 04:31 PM
