Trucks won't run worth a crap above 5k ft.
Old Feb 6, 2013 | 01:19 PM
93-p-pumper's Avatar
Hey guys so my truck has been running fine lately except I went to visit my parents 4 hours away last week n climbing a pass my truck started to run like it had air in the lines, ran rough, wanted to die if I let off the pedal if I thevered it I could make it wanna pick up RPM's again then some times RPM's would hang. It with it till I got lower down like below 5k feet. Coming home it did the exact same thing on that pass. I wanna go back in a few weeks but I don't want this problem again. I can't find any fuel leaks. So I can't see it being air getting in but that's all I can think of. Anyone got an idea?
Old Feb 6, 2013 | 06:25 PM
infidel's Avatar
I live at almost 5k and haven't noticed a problem but my understanding is timing higher tham 16° can cause problems at high elevation.
Old Feb 6, 2013 | 07:06 PM
My timing is stock as far as I know.
Old Feb 6, 2013 | 07:18 PM
HOHN's Avatar
Timing was my first thought, too.
It's worth confirming.
Higher altitude benefits from higher compression and less timing.
JH
Old Feb 6, 2013 | 08:27 PM
whiskers's Avatar
Check your air filter. if it's marginal it will cause problems at altitude, thinner air.
Old Feb 7, 2013 | 12:11 AM
joem's Avatar
the 6bt should be able to create the same required boost PSI well above 15k feet as it does at sea level- they use PSD and cummins on MT loa in Hawaii at 16,000 feet and during my tour I still saw 20psi when the guy was at 1/4 throttle, maybe something that is more effected by thin air like fuel cap, cracked lines?
Old Feb 7, 2013 | 12:15 PM
Air filter is new, I wanna get a timing gauge, I tightened my gov springs about a month ago that shouldn't do it though. I have no fuel leaks either.
mt250
Aug 17, 2012 09:09 PM
Spooler
May 26, 2011 12:27 AM
ppsi
13
Apr 13, 2004 03:49 PM
