Truck needs a little more ...
Hi Guys
I'm working on my new dodge toy ...LOL , I got my new fan bearing block today ... I started to install my new lower rad hose and found my amsoil system needs new hoses ...I did not like where it was mounted , right now the hoses are 4ft , I would like to add 2ft to each hose so I can mount the filters off the frame ...I'm going to build a rock sheild ... My big question is about the charge tube rubber connectors ...The truck ran very strong before I took it off the road for all the maintance ...I just found a 3/8 hole in the rubber connector for the intercooler that comes off the turbo side , the other side is showing signs of wear but no holes . Where can I order these new connector hose's . Thanks Guys Greg |
Piers has them, I've seen them elsewhere too, but not sure about the $ or quality differences?? but like I said I know for sure you can get 'em from Piers.
Re: Piers
I'm not fimilar with piers ...?
Would any one know the size of a replacement O-ring for a amsoil remote by pass , I called my amsoil buddy and he said they had there own part# and did not disclose the size , is the part that screws on to the oilfilter mount ... I think it's like a 230 but I will have to do some more research , but if one of you gentleman might have a O-ring # sitting around that would be great . Thanks guys Greg |
Piersdiesel.com in Canada eh
haisley has them $75 lower boot and $55 upper boot
http://www.haisleymachine.com/PERFOR...20PRODUCTS.htm |
PiersDiesel is highly recommended.
Mr Bob's Distributing has a very interesting looking hose kit. |
I got the Piers hd boots FWIW just get the lower boots and all the clamps. The reason why I say that is cause the upper "boots" are nothing more 5" pieces of 3" ID silicone coolant hose as mine say right on them. You could theoretically buy a foot of 3" silicone coolant hose as I recall the Gates #24852 for maybe $35-$50.......................JMHO
Re: O-ring and lower hose's
Hi guys
The O-ring was a 230 ...I order a pack of viton ...10 bucks . I tried to track down the lower intercooler hoses locally ... not a chance , I order them from Haisley ...not $75 a pop ...I ordered 2 . Later guys Greg |
