Trany Cooler
Old Dec 30, 2006 | 07:40 PM
1ST CUMNZ's Avatar
Trany Cooler
Good evening gents,it's been awhile hope everybody is have a nice and safe holiday.Has anyone used or have thoughts on using a a/c condensor for a trany cooler ? What are your thoughts on by passing the coolers already on the truck eg the one in front and the one on the engine.
Thanks again in advance Luc
Old Dec 31, 2006 | 12:13 AM
Fueling around's Avatar
pretty good thread over in Performance & Accessories
https://www.dieseltruckresource.com/...d.php?t=129728
Old Dec 31, 2006 | 07:24 PM
1ST CUMNZ's Avatar
Thanks for the tip,did read it made sense now how about the condensor for a cooler ??? any thoughts ?
Old Jan 1, 2007 | 12:52 PM
rhino 660's Avatar
i have been wondering the same thing because my condensor is just sitting there doing noting and that would make a killer cooler maby over kill. but i think it will work no prob
Old Jan 1, 2007 | 01:18 PM
1ST CUMNZ's Avatar
Exactly,through a fan on it put under the bed,would be cheaper than dishing out a couple hundred bucks to b&m for one.
Old Jan 1, 2007 | 01:40 PM
I've been pondering this one. Coolers use slightly different designs for gas & liquid. Usually a gas cooler (freon) is much higher capacity. It should work ok as A/C is higher pressure than trans fluid and the coller materials are similar.
Old Jan 1, 2007 | 02:15 PM
1ST CUMNZ's Avatar
I'am pretty sure it should work,most cooler (tranny) resemble a consensor anyway,and most have 1/2 lines
Tank_66
Jan 11, 2012 10:12 AM
endurancerider
Oct 6, 2011 08:32 PM
auber
Nov 12, 2007 11:39 AM
8secondride
13
May 25, 2003 01:49 PM
bigfoot
Oct 8, 2002 04:17 PM
