Transmission shifting problem
Hi I have A 94 Dodge with a 47rh in it. I Have replaces the tps. But is is still shifting in and out of 4th gear. When i drive like 5 miles it starts to stay in 4th gear. i was think abouth the tv cable where is that located.
Thanks
Thanks
I've had a similar issue. But, it may go a month or two between doing it. I'm pretty sure it's the converter locking and unlocking on mine. It only does it at a steady speed. Just the slightest acceleration and it will lock back in. It's happened only during the AM commute. I've never had it happen on the drive home, even if it sat idle for 8-9 hours.
When my alterater is chargen thats the only time its unlocking and locking. Just saying someone told me to rap foil around the wire from the alterater to the passenger battier to the pcm.
wrangler04
Mar 13, 2008 05:17 PM
