Transmission plug Location (99 3500 Manuel transmission)
NV4500 is 4 quarts, don't cheap out, get the good stuff. Amazon has it usually around 23-24 bucks a quart. I bought a cheap 5 dollar hand pump that screws into the bottle, made it super easy and no spillage of the precious fluid.
6 Speed Manual Transmission
Introduced in the 1999 model year - few were built before the 2001 MY.
Option code DEE
Manufactured by New Venture Gear
Input Shaft: 1-3/8" 10 spline (after Aug 99)
4x4 Output Shaft: 1-1/2" 29 spline
Input torque rating 550 ft-lb
GVWR: 16,000 lb
GCVWR: 26, 000 lb
Cast Iron case, weight = 360 lb
Fluid Capacity: 9 1/2 pints
Texaco Code 1874 MTX (specs.pdf)
Mopar 4761526
Dodge spec MS-9224 oil*
Fill port: on driver's side, requires a 17mm Hex wrench
Design & Features from Mastertech issue #11
RPM Comparison 5-speed vs 6-speed
If the NV5600 6-speed, Valvoline MTF, which meets the Chrysler spec. Valvoline shifts better for me than the Pennzoil version, and the Chrysler fluid is too expensive.
I believe its 5 qts, but should be run a quart high. There’s also a thin magnet at the bottom of the case that should be cleaned. Access is through the PTO cover. Can’t remember which one provides the easier access, but I think its the right cover.
http://www.carquestprofessionals.com...0%206.6.13.pdf
ezdemon72
05-26-2005 06:18 PM
