Transmission Cooler line Question?
The flexible rubber hose that connects to the underside of the water to oil transmission cooler is leaking. Im having a hard time finding a replacement part. Do any of you guys part #s / and can it be found elsewhere beside the dealership?
Thanks,
Dave
Thanks,
Dave
This is the one you want. It has the tee in it for a temp gauge and includes the whole steel line with the rubber section too. List at the dealer is $159. I just got mine yesterday.
Don't know any way to get one cheaper unless you have a "hose-man" near you. We have some locally that will "rebuild" your old line for you with new rubber. Something like that would probably be $60+
Having a shop make one up is the way to go. If that is not an option, just do what Infidel suggests. I would look for hose that is called"transmission hose". Some of your better auto supply houses have it.
While pressure is not really a problem, heat can be. I believe transmission specific hose is rated to 300 degrees.
BTW, that rubber section contains a check valve. It is supposed to prevent the torque convertor from emptying when sitting. I removed mine and have not noticed any issues other than a slight decrease in fluid temps. Others report the same results. The check valve is smaller than the ID of the rest of the transmission hoses. KD
1NGENRO
Sep 27, 2012 09:26 PM
xxwildbillxx
Jan 29, 2011 08:03 AM
isb07
Nov 18, 2009 05:12 PM
pulpwood007
Sep 28, 2006 04:40 PM
