trans woes, cps, tps or other thoughts 4 fix
Old Dec 3, 2012 | 05:19 AM
neverhme's Avatar
did lots of searching, read up on the tps, but am wondering if the crank sensor is off. Is it adjustable?, haven't been able to find that info. Had my local indy do the outer front cover seal/ dowel pin and trans is hunting bad. Started the truck once, and no tach, but has since been working fine.
Old Dec 3, 2012 | 11:58 AM
infidel's Avatar
Old Dec 3, 2012 | 12:16 PM
neverhme's Avatar
thank you infidel. will check that. I sprung for a new tps and installed it, test ride gives it a thumbs up, shifting fine. I will be checking speed sensor as the tach has always worked. Is the speed sensor something that gets removed when working on the outer cover? Maybe the pulley got some crud on it, and isn't sending the signal strong enough.
Old Dec 4, 2012 | 10:54 AM
infidel's Avatar
Yes, the ESS has to come off to remove the cover.
I've never heard of crud affecting the sensor but suppose it's possible.
Old Dec 8, 2012 | 02:47 PM
cromulius's Avatar
When my speed sensor died I lost the tach and air conditioning. New one fixed everything.
whosdunit
May 17, 2014 08:54 AM
Joe V
Sep 8, 2006 06:01 PM
John In NC
Oct 22, 2005 09:14 AM
dzpoorjr
Jan 22, 2005 10:29 PM
Dodgezilla
Jul 17, 2004 05:24 AM
