Trans temp question
Old Oct 14, 2009 | 06:41 PM
Onemoparnut's Avatar
Trans temp question
My buddy has a 96 2500 4X4 and it wont shift into overdrive. I hooked up my scanner and it says the trans temp is 14,663 degrees. What could cause the computer to get a reading that far off?
Old Oct 14, 2009 | 07:18 PM
infidel's Avatar
An open circuit to the trans temp sender results in a low reading.
Supply voltage to the sender is 5 volts.
Seems like if you are getting such a high reading that the signal voltage back to the computer is in excess of 5 volts.
I would suspect a short to 12 volts somewhere in the wiring.
Could also be your scanner. Pre '97 trucks use the DBR Chrysler only system, not OBD.
Unless you paid in excess of $2000 for software it could be what's wrong.
Old Oct 14, 2009 | 09:27 PM
The scanner is a snap on scanner when it was new it was in excess of 2000. It reads everything else ok just the trans temp is way too high. That high reading would also keep it out of od but not sure where it even reads trans temp. I dont see a sensor like my first gen has.
Old Oct 15, 2009 | 09:57 AM
infidel's Avatar
On a '96 the sensor is internal, you have to drop the pan to get at it.
Old Oct 15, 2009 | 09:01 PM
ok thanks for the help
1985cucv
Feb 18, 2010 02:03 PM
mar67655
Mar 21, 2009 05:35 AM
Richpwb
Aug 15, 2008 08:01 PM
djgaston
Oct 30, 2005 03:18 PM
live wire
Jul 21, 2003 07:26 AM
