trans problem or ?
trans problem or ?
-hey guys, gotta customers truck here with a problem
98 3500 auto 4x4 12 valve
trans pulls off in 2nd (like its in limp)-but no codes present
on scan tool trans relay turns off after intial key on cycle
also tach is not working-there is also no rpm shown on the scan tool either
any help would be appritiated!
-update
i found that the asd relay is also losing its signal from the pcm to keep it powered up
if i apply 12 volts directly to the 87 terminal of the relay, the transmission relay stays powered up and the transmission shifts perfect but the tach still dosent work
also a/c dosent work
im starting to think there is somthing goin on withe the pcm
well- you sir are the man!
-replaced crankshaft sensor on the front of the engine and everything worked perfect. I didnt think it would run if the sensor was bad, but it did!
thank you again
I owe you a beer!
thank you again
I owe you a beer!
Les Eid
Feb 13, 2008 09:22 AM
nfsommer
Nov 9, 2007 09:36 AM
djgaston
Oct 30, 2005 03:18 PM
live wire
Jul 21, 2003 07:26 AM
