Which Trans Line is it?
Old Dec 5, 2011 | 07:40 PM
flyingd's Avatar
The hot trans line to put the trans temp sensor in; is it the one that goes from the trans to the heat exchanger, or is it the line that goes from the trans to the cooler and then the heat exchanger.
Also, if I end up putting the tee in, what did you use to cut the line with?
Thanks
Old Dec 5, 2011 | 07:56 PM
BigIron70's Avatar
Cummins Guru
The front trans cooler line is the hot fluid to the ext cooler. Use a tubing cutter to cut line if installing a T for temp sensor.
isb07
Nov 18, 2009 05:12 PM
Bradleysram
19
May 12, 2009 08:36 AM
Trooperthorn
Jul 25, 2008 10:39 AM
RoadDiesel
Jun 16, 2007 09:24 PM
ckennedy
Jun 23, 2006 08:21 PM
