tranny shifting
Old Feb 9, 2021 | 12:59 PM
mybajadodgeram's Avatar
tranny shifting
I have a 96 ram 3500 original owner. The original trans was rebuilt in 2012 to include billet input and output shafts and a triple plate torque converter along with a few other goodies. All has been well until recently. Now when the trans is cold in the morning it shifts perfect however when it gets to operating temp it doesn't want to shift unless you let off the fuel pedal, dropping the RPM, and it shifts. I have done the fluid and filter change and did not make a difference. ANY IDEAS?????
Thanks for the help
Old Feb 9, 2021 | 03:48 PM
texasprd's Avatar
Is that on all shifts, or only certain shifts?
Old Feb 10, 2021 | 10:53 AM
On all shifts
Thanks
Old Feb 10, 2021 | 11:14 AM
AlpineRAM's Avatar
Did you check the valve body bolts for tightness?
The reason is that as the fluid gets thinner leakage gets more evident- and if you have a leak from the governor circuit it will do what you describe.
wrangler04
Mar 13, 2008 05:17 PM
hotmopr
Nov 27, 2004 11:51 AM
Cumminstd1996
Oct 20, 2004 01:31 PM
Tom Bolitho
Oct 12, 2004 06:46 PM
Dodgezilla
Apr 1, 2003 11:14 AM
