TPS Voltage
Old Aug 31, 2005 | 04:50 PM
Rrloren's Avatar
TPS Voltage
The dealer told me today my TPS voltage was high and needed to be replaced. They want $470 to do ! I thought that was pretty high . To me the truck doesn't seem to shift bad.
They also told me that the voltage can't be adjusted but I thought I read here that it could be?
Is this a serious problem or not? As I said the thing seems to shift OK , may creep a bit at idle with foot off brake but not real bad. Just worried if this thing will leave me on the side of the road somewhere. Will it continue to get worse? What do you guys do when you uncover this problem? Thanks for any advice.
Old Aug 31, 2005 | 07:16 PM
infidel's Avatar
Start by checking/adjusting the voltage yourself, don't trust the dealer.
Instructions here http://dodgeram.org/tech/transmissio...TPS_adjust.htm
Old Sep 2, 2005 | 02:22 PM
bob4x4's Avatar
If you had a code for tps voltage high,you could have an open ckt.Check your voltage and go from there.
Bob
Old Sep 2, 2005 | 02:33 PM
Rrloren's Avatar
Excuse me for for not knowing but what do you mean by open ckt?
Old Sep 2, 2005 | 03:12 PM
Boatnik's Avatar
When you turn off a switch, you open it. The light is off.
If you close the switch the circuit is completed. The light is on.
The same logic for a tps circuit. Look for loose or broken wire.
imbodie
21
Jan 8, 2024 08:49 AM
whosdunit
May 17, 2014 08:54 AM
John H
Nov 3, 2003 01:55 PM
Paradise Racing
Mar 18, 2003 06:26 PM
pull superbee
Mar 11, 2003 01:11 PM
