Tps
Old Dec 6, 2007 | 08:02 AM
DIESELDENT's Avatar
Tps
the check engine light on my 95 came on when i started it this morning. checked it using the key on off on off on way and it came up 24 which is tps voltage to high or low. also the volt meter isnt going above 12v. havent had a chance to get a volt meter on it yet. just wanted to see if any one thought it could be adjusted or cleaned, or is it just dead when a code comes up.
Old Dec 6, 2007 | 09:00 AM
ratsun's Avatar
I thought the key cycle code reader didn't work on any thing prior to 2000?
Is your trans shifting funny?
The low voltage could be a alt problem.
Old Dec 6, 2007 | 09:26 AM
DIESELDENT's Avatar
the key thing works on 94-96 as well. the trans isnt locking up like it used to, but seems to be shifting fine. it came up with a code for the tps i cant remember where i read it but if theres a problem with the tps it doesent let the alt charge.
Old Dec 6, 2007 | 09:35 AM
DIESELDENT's Avatar
this is the link for reading codes
http://dodgeram.org/tech/dsl/trouble..._DTC_codes.htm
Old Dec 6, 2007 | 09:48 AM
infidel's Avatar
The only ones it doesn't work on are '98 & '99
Old Dec 6, 2007 | 10:16 AM
ratsun's Avatar
Ahh I see
I know it dosent work on both my 98s
Old Dec 6, 2007 | 09:34 PM
oldblues's Avatar
hi
no no no !
it in fact DOES work on the 98 s
press and hold your trip meter button in
turn on ignition , off , on, off , on leave on at this point and release the trip meter button .
it should now go through a checking cycle for app 30 sec you will see the speedo and tack stop at several locations during cycle .
it ill finish shortly after the spedo/tack test wait for it to finish .
give er a try and see !
Old Dec 6, 2007 | 09:35 PM
oldblues's Avatar
hi
no no no !
all warning lights will flash on
Old Dec 8, 2007 | 09:09 PM
ratsun's Avatar
Humm...I tried what you said and all I managed to do was reset my trip meter ? Tach and speedo never moved or anything either?
whosdunit
May 17, 2014 08:54 AM
Paradise Racing
Mar 18, 2003 06:26 PM
hvanflee
Mar 13, 2003 03:11 PM
feets
Jan 1, 2003 11:04 PM
