torque lock switch
It's super easy, but it will destroy the stock trans quick. There is not enough line pressures to keep from slipping the TC clutch without some mods. You really need a good aftermarket converter and valve body to be able to utilize this switch, and at that point you'll find you don't really need it either.
The mod requires a resistor, switch, 10ft of wire, and about an hour of time total (this is at most)
If you want to fry your stock TC, I'll tell you how to do it, but I don't have the info at hand right now, I'll get it and post back if you still want it. I'm not trying to sound like a jerk, just want you to know the risk of adding this to a stock trans.
George
George
All you need is a switch and some wire. I dont know why you would use a resistor. Under the hood on your passenger side there is a connector for your computer. There is an orange wire with a black tracer (pin 54 or 56).
Tap into that wire and run that to one side of your switch run the other side of the switch to a ground. When the switch is activated the tc will lock up when second gear hits. THE TRANNY WILL NOT DOWN SHIFT UNTIL THE SWITCH IS TURNED OFF.
I love mine
Like gstanfield said it will tare up a stock tranny.
I love mine
Here's good instructions
http://www.tstproducts.com/Torque%20...p%20Switch.pdf
Installing the resistor will enable you to shift all you want with it locked. Up down sideways, whatever
It is giving the computer a signal of something (I don't know what for sure) and fooling it into locking it up while still allowing you to shift as needed. I think it is a 33ohm resistor, not sure, but I do have the radio shack part # here somewhere.
George
It is giving the computer a signal of something (I don't know what for sure) and fooling it into locking it up while still allowing you to shift as needed. I think it is a 33ohm resistor, not sure, but I do have the radio shack part # here somewhere.George
I'm sorry George but what you say makes absolutely no sense.
The lock up system was designed for a signal straight to ground. Although with a resistor, especially a 33 ohm one, it still will work there is no benefit at all from a resistor.
It's almost like introducing a bad connection into the system.
Somebody set me straight here. I've heard that your trans won't downshift once you've activated the switch even after turning it off until you come to a complete stop. Is this true? If so, has anybody tried to trick the PCM into thinking you've stopped by putting a momentary disconnect in the wires from the VSS?
No need to stop, just turn the lockup switch off.
I wondered about it when I read the directions, but I followed them and they worked (just so you know I worked as an electrical engineer / Heavy truck electrician for 6 years, I know eletrical and I understand your comment about creating a "bad connection" ) I'm not trying to start crap, just telling you this was per my directions and it works perfect.
George
Here's more confusion for the pot. I read the instructions above, and they aren't even close to what mine were. My instructions did not require a jumper for the hot wire. Mine just required the switch to ground via resistor.
I'm really not trying to be contrary here, and I'll even shoot a video of me running my truck through the gears up and down with it locked for those who think I'm looney.
George
George
THURENfab.
33
Aug 4, 2016 10:30 PM
ataboy9026
Jun 9, 2006 09:08 PM
mr T
21
Jun 1, 2005 08:48 AM
mr T
May 15, 2004 09:41 PM
