timing knock... stock?
Old Jun 1, 2006 | 07:38 PM
BCB's Avatar
BCB
On the 1997 2500 in sig. it has a knock when the motor is cold. and my MPG took a dive a little before this happened. has my timing sliped below stock or am i completly off?
Old Jun 2, 2006 | 02:20 PM
BCB's Avatar
BCB
no one?
also if you give it a little fuel to rase the RPM it goes away also
Old Jun 2, 2006 | 03:44 PM
northslope's Avatar
In some the posts I've read on lift pumps they can have a tendancy to "knock" or be noisy when on death row. Don't hold me to it but it's a thought.
If it does turn out to be the l/p JMHO but I'd rather change the fuel filter than have to change the l/p!
Old Jun 2, 2006 | 04:31 PM
GAmes's Avatar
My first thought was the lift pump. I replaced mine at about 370k cuz it was ticking but saw no performance problems. I bought mine from a Case dealer, cost less than from Cummins but had to swap one of the fittings. If you do replace it don't forget the L-shaped hose (about $7 from the dealer) to the fuel heater. They come out as an assy anyway.
Zee
Mar 23, 2010 09:54 PM
HappyGA
15
Oct 16, 2006 08:21 AM
Hoss
30
Oct 3, 2006 02:57 PM
sinwagon2500
16
Jan 10, 2004 01:34 PM
