throttle linkage
Linkage is supposed to be a set length, I think 5"
If the cable needs to be adjusted that means it has stretched and should be replaced.
The threaded rod I speak of is towards of the linkage rod, you can see the double nuts on it.
This is the 97-98 recall
http://dodgeram.info/tsb/recalls/B15.htm
Both illustrate the bell crank to throttle rod setting. If you change the setting on an auto is screws up the kick down cable and TPS.
Actually, the 94-96 recall points to where you can temporarily fix a stretched throttle cable. Add shims between the cable stop & cable retainer
cLAYH
Feb 6, 2004 10:59 AM
