-   12 Valve Engine and Drivetrain (https://www.dieseltruckresource.com/forums/12-valve-engine-drivetrain-100/)
-   -   Thin Injector Washer Size? (https://www.dieseltruckresource.com/forums/12-valve-engine-drivetrain-100/thin-injector-washer-size-85148/)
berner Dec 7, 2005 04:18 PM
Can anybody tell me how thick the thin injector washers are? I'd like to pick some up locally and want to make sure I get the right ones.
Thanks
Ponci Dec 7, 2005 10:58 PM
The thin washers are .020.
SHARPMACHINE Dec 8, 2005 07:10 AM
NOT trying to hijack this, just same type of question.
Are the washers the only thing needed to install differant injectors? I know thet they can not be reused, but would like to know why they cant and if their is anything else that someone would need???
What if the old washer was ground down to .020??
thanks
berner Dec 8, 2005 08:12 AM
Thanks Ponci
Sharp - You'll need some return line washers as well. Make sure you clean up the return line mating surfaces with some emery paper to prevent leaks.
The reason for not re-using the injector washers is that they become misshaped due to slight imperfections in the head and/or injector body. They are, in effect, a gasket. The manufacturer would have to machine each injector and each injector bore in the head to very high tolerances to achieve a perfect sealing surface. The cost of doing this would be far greater than using a copper washer.
infidel Dec 8, 2005 10:31 AM
Don't automatically assume thin washers, or thick ones for that matter, are what you need. The depth of the injector tip into the cylinder determines the radius of the spray pattern. The washer thickness adjusts this, not all injectors need the same thickness washer and it's impossible to figure it out on your own.
The only way to determine the washer thickness for your particular injector is to ask the vender or manufacturer.
Don M Dec 8, 2005 12:02 PM
Bill is correct. As usual.
Don~
berner Dec 8, 2005 05:46 PM
Thanks Bill & Don
I've installed stock rebuilt 215's. I get a fair bit of hazing at idle until the truck is completely warmed up. My plate is in the stock position. The Gov lever hits the plate right at the bottom tip. Timing is at 15.5. The O/F valve was changed 2 years (30K km) ago. I can lay down a pretty good cloud of smoke right through the RPM range. I'm trying to get my mileage up a bit.
From what I've read, the thinner washers are supposed to give you a better spray pattern. Do you know what size washers usually come with stock 215's?
Thanks
halerazor Dec 9, 2005 12:08 AM
thin washers are on the 215 injectors at least the 4 sets i've pulled. call haisley machine they sale them for 50 cents each
SHARPMACHINE Dec 9, 2005 06:41 AM
Does Haisley sell the return line gaskets as well??
halerazor Dec 9, 2005 11:25 AM
i'm sure they do just call them and ask
SHARPMACHINE Feb 3, 2006 08:51 AM
Could I get their web address and phone # please?
thanks again
halerazor Feb 3, 2006 12:10 PM
www.haisleymachine.com
SHARPMACHINE Feb 3, 2006 12:26 PM
thanks - much appreciated
jimk Feb 3, 2006 09:36 PM
Bill is correct, and I used the thin washers to describe the washers, and some where I have the correct thickness. However when I got the kit from Piers the kit had different size washers. I used the thicker washers to begin with and the truck did not run as good as I thought it should. After pm to a fellow I learned to use the thinner washers in the kit. That made a big difference, believe it or not. I should have posted the correct number, I believe that by using the different thickness washer and the timing makes a difference in mileage and power. Good luck Jim
northslope Feb 4, 2006 05:58 PM
50 cents a piece is dirt cheap. I ordered 6 yesterday for a customer's rock drilling machine with a 6c in it, the washers from Cummins n/w were $3.25 EACH, I asked "each?" he said "yes, $3.25 each" WOW!
