Thin Injector Washer Size?
Old Dec 7, 2005 | 04:18 PM
berner's Avatar
Can anybody tell me how thick the thin injector washers are? I'd like to pick some up locally and want to make sure I get the right ones.
Thanks
Old Dec 7, 2005 | 10:58 PM
Ponci's Avatar
The thin washers are .020.
Old Dec 8, 2005 | 07:10 AM
SHARPMACHINE's Avatar
NOT trying to hijack this, just same type of question.
Are the washers the only thing needed to install differant injectors? I know thet they can not be reused, but would like to know why they cant and if their is anything else that someone would need???
What if the old washer was ground down to .020??
thanks
Old Dec 8, 2005 | 08:12 AM
berner's Avatar
Thanks Ponci
Sharp - You'll need some return line washers as well. Make sure you clean up the return line mating surfaces with some emery paper to prevent leaks.
The reason for not re-using the injector washers is that they become misshaped due to slight imperfections in the head and/or injector body. They are, in effect, a gasket. The manufacturer would have to machine each injector and each injector bore in the head to very high tolerances to achieve a perfect sealing surface. The cost of doing this would be far greater than using a copper washer.
Old Dec 8, 2005 | 10:31 AM
infidel's Avatar
Don't automatically assume thin washers, or thick ones for that matter, are what you need. The depth of the injector tip into the cylinder determines the radius of the spray pattern. The washer thickness adjusts this, not all injectors need the same thickness washer and it's impossible to figure it out on your own.
The only way to determine the washer thickness for your particular injector is to ask the vender or manufacturer.
Old Dec 8, 2005 | 12:02 PM
Don M's Avatar
DTR Advertiser
Bill is correct. As usual.
Don~
Old Dec 8, 2005 | 05:46 PM
berner's Avatar
Thanks Bill & Don
I've installed stock rebuilt 215's. I get a fair bit of hazing at idle until the truck is completely warmed up. My plate is in the stock position. The Gov lever hits the plate right at the bottom tip. Timing is at 15.5. The O/F valve was changed 2 years (30K km) ago. I can lay down a pretty good cloud of smoke right through the RPM range. I'm trying to get my mileage up a bit.
From what I've read, the thinner washers are supposed to give you a better spray pattern. Do you know what size washers usually come with stock 215's?
Thanks
Old Dec 9, 2005 | 12:08 AM
halerazor's Avatar
thin washers are on the 215 injectors at least the 4 sets i've pulled. call haisley machine they sale them for 50 cents each
Old Dec 9, 2005 | 06:41 AM
Does Haisley sell the return line gaskets as well??
Old Dec 9, 2005 | 11:25 AM
halerazor's Avatar
i'm sure they do just call them and ask
Old Feb 3, 2006 | 08:51 AM
Could I get their web address and phone # please?
thanks again
Old Feb 3, 2006 | 12:10 PM
halerazor's Avatar
www.haisleymachine.com
Old Feb 3, 2006 | 12:26 PM
thanks - much appreciated
Old Feb 3, 2006 | 09:36 PM
jimk's Avatar
Bill is correct, and I used the thin washers to describe the washers, and some where I have the correct thickness. However when I got the kit from Piers the kit had different size washers. I used the thicker washers to begin with and the truck did not run as good as I thought it should. After pm to a fellow I learned to use the thinner washers in the kit. That made a big difference, believe it or not. I should have posted the correct number, I believe that by using the different thickness washer and the timing makes a difference in mileage and power. Good luck Jim
Old Feb 4, 2006 | 05:58 PM
northslope's Avatar
50 cents a piece is dirt cheap. I ordered 6 yesterday for a customer's rock drilling machine with a 6c in it, the washers from Cummins n/w were $3.25 EACH, I asked "each?" he said "yes, $3.25 each" WOW!
1972RedNeck
Jun 3, 2013 10:09 PM
frostytj
Apr 20, 2007 11:32 AM
edy
Mar 4, 2007 06:36 PM
mhuppertz
Nov 23, 2006 06:48 PM
fordsux8269
Dec 9, 2005 12:17 AM
