TC locky up switch again...
Old Sep 29, 2005 | 11:25 PM
dodgeman01's Avatar
I ready the TST page and it seems simple but I was wandering if it would work like normal with the switch off? DO I have to use a three position switch or if I just turn the switch off will it lock and unlock like it does stock?
thanks
DM01
Old Sep 30, 2005 | 09:55 AM
infidel's Avatar
Just a single position switch in the off position and your trans will work like stock
Old Sep 30, 2005 | 10:00 AM
dodgeman01's Avatar
Thanks man
DM01
Old Sep 30, 2005 | 11:39 AM
Mcmopar's Avatar
Look in my gallery, there are a couple ways to do it.
Old Sep 30, 2005 | 04:19 PM
dodgeman01's Avatar
I did it the way TST said to and it works great 15 minutes and I was cruisin own the road a lot faster with no TC in ou crap. Only thing is that I can slip the TC on a basicly stock motor But like I said I'm happy until the TC goes out then its Suncoast time for me.
DM01
Old Sep 30, 2005 | 04:43 PM
Mcmopar's Avatar
If that is the case you better put a shift kit in it now!!
Old Sep 30, 2005 | 09:38 PM
dodgeman01's Avatar
Is it the TC clutch that is slipping? or the tranny? what would a shift kit to for the TC
DM01
Old Oct 3, 2005 | 08:29 AM
Mcmopar's Avatar
A shift kit will enlarge the holes that supply oil to the T/C lockup, you also increase the pressure going to the T/C which will hold more power. You also replace a spring in the 3-4 accumulator piston to make the shift quicker and more firm, less chance to "shudder".
Steven K
Jun 4, 2009 10:32 AM
b84u
Feb 20, 2006 01:04 PM
chuck3
Feb 1, 2005 07:47 AM
gunracer1
18
Nov 24, 2003 08:56 AM
Sean S
Nov 15, 2002 12:25 PM
