T&R Overdrive
Old Mar 31, 2016 | 05:51 PM
Albatross243's Avatar
T&R Overdrive
Steering has some slack, I'm thinking this is going to require a new steering box. Is there a fix short of this that works or do I go ahead and bite the bullet and replace it.?
Old Mar 31, 2016 | 06:10 PM
gorms's Avatar
You can tighten up an adjustment screw, IIRC its a 3/16 Allen head with a check nut on top of the box. Go in small- 1/8th turn increments. If the steering gets notchy back it off a little.
Make sure all other components are tight, tie rods/ball joints/track bar/steering shaft as well. Steering brace did a lot for mine once everything else was done.
Old Apr 1, 2016 | 08:03 AM
loose steering
Thanks, thats promising info, I'll post results
RTCRam
Oct 4, 2012 01:43 PM
72demon440
Apr 27, 2007 10:45 PM
max001
Jun 23, 2005 12:24 PM
rackshakermac
Sep 8, 2003 07:28 PM
