Pressurized oil leak . . POURING OUT !
Old 10-28-2018, 06:34 AM
JMZ
JMZ's Avatar
Had to get a buddy to come load my truck up yesterday . Lost oil VERY FAST . Its coming fro around the IP / oil sensor location . Obviously its a pressurized leak . Any assumptions ? I did the KDP fix years ago . This leak HAS to be pressurized.
Old 10-28-2018, 07:08 AM
Received 2,380 Likes on 1,573 Posts
Rusted out stainless braided line [s] that run to the power steering unit or the injection pump are my first guesses.
Tappet cover gasket can make a good leak as well if a chunk of it falls out.
JMZ (10-28-2018)
Old 10-28-2018, 10:15 AM
JMZ
JMZ's Avatar
Thanks for the reply. Just found out its the sending unit . Now, do I put another one in it or go to a mechanical set up ?
Old 10-29-2018, 03:53 AM
AlpineRAM's Avatar
I'd get a replacement sender from Cummins- yours lasted 21 years, the next one should do too.
Basic problem with mechanical gauges is that you have a much longer and much more exposed oil pressure line that can fail and dump your oil again.
That'S why almost every manufacturer went electric for the gauges a long time ago- cheaper and more reliable.
JMZ (10-29-2018)
Old 10-29-2018, 05:31 AM
JMZ
JMZ's Avatar
I`m going to order one today.
horselady
07-08-2012 08:49 PM
DNRCustoms
06-25-2009 12:17 AM
bhallo0217
08-07-2007 07:01 PM
93Dod350TB
07-03-2006 02:51 PM
tinman1911
11-12-2005 10:39 PM
Quick Reply: Pressurized oil leak . . POURING OUT !
