Studs and Marine gasket only? Who's done it? What turbo and PSI?
I've got to replace a leaky head gasket soon. It's not leaking internally from what I can tell, just on the outside of the block at #1 and #6, but it's starting to POUR.
I'm going to install ARP 12MM studs and a .020+ Marine gasket. (No o-rings for the time being) After this, I plan on adding New Era 370s, some 181 DVs, bumping the timing to 16° and I'm assuming I'll have EGT issues. -Are the studs and marine gasket enough for a turbo change? -What turbo housing should I install to help control EGT problems with the 370s and new DVs? -What kind of pressures will the marine gasket and studs take? I don't have the time to get the head ringed. I'll be lucky if i have time to have it checked for straightness. Any suggestions? Thanks. Conn |
that is what i am running on my dually, i have a hx55 on it and run 55 or so pounds of boost, and 20 degrees of timing.
i know a guy on cumminsforum that has 12mm studs, .020 over hg, and he has twins and runs sometimes up to 75psi and has been running it like that for a while now.
But, he went through the LONGEST retorquing period i have ever heard of. He went like 2 days, 5days, 1week, 2weeks, and then a month in between retorques. All and all, he did not pull over 20lbs boost for about 2 months. The whole time he was constantly retorquing. Talk about maximum sealing. |
Originally Posted by gunracer1
(Post 1237116)
my truck just poped one with (12mm studs, marine gasket, it was milled flat and retorques were done) 50 psi boost 23* timing hx50 charger
I am all stock. [duhhh] 50 PSI
I have been running up to 65 with a stock gasket and studs. The head was flattened and we did 4 retorques. If you don't get it cut I think you are wasting your time. My head was .013 out of whack, as long as they are I don't think you will hardly find a flat one.
if i can find another head to have ringed and decked while i can still drive mine, then i'll probably go ahead a ring it. it's relatively cheap insurance.
| All times are GMT -5. The time now is 03:28 AM. |
