Starting problems
Old Oct 18, 2005 | 01:57 PM
mullady76's Avatar
Starting problems
Newbie here. I have a 97 with 140,000+ mile on the clock. It just started giving me starting problems. When I turn the key, she cranks over but doesn't start. It did this about a month ago and I replaced the fuel shut off seloniod which seemed to fix the problem. Now it is starting again. Any ideas?
Thanks,
Sean
Old Oct 18, 2005 | 03:07 PM
turbo thom's Avatar
Check the idle speed. On the 5 speed it's 900 rpm, on the auto it will be 750. Which so you have?
Old Oct 18, 2005 | 03:24 PM
mullady76's Avatar
Its an auto. I know the idle is set low. I press down slightly on the pedal when starting it. I dont want to adjust the idle cause i have the truck neutered to pass inspection. Then I will readjust the plate and afc.
Have people had problems with the relays? I know it has nothing to do with the starter motor. I replaced it with in the past 6 month and added bigger contacts.
Old Oct 18, 2005 | 06:50 PM
infidel's Avatar
A bad relay or more often a corroded blue wire off the driver's side battery are usually the problem.
I have no doubts that your old solenoid was perfectly fine.
Many times people think they have fixed the problem by replacing the solenoid when all they really did was move a shorting wire around till it made short lived contact again.
fourthandgoal
88
Dec 27, 2011 05:39 AM
DJ Turbo.
Oct 13, 2011 09:11 PM
RED99CTD
Apr 20, 2011 08:08 AM
abc4yew
Mar 15, 2007 11:55 PM
doodah
17
Dec 17, 2002 12:55 PM
