starter or ignition
Old Jan 20, 2010 | 12:06 AM
leftfield's Avatar
starter or ignition
Hi guys , here's my problem. Sometimes when I go to start my truck (98 12v) it may start right up or it might turn over a few times then stop turning over. I immediatly try it again and it may or may not start, try it again and then it does. I'm pretty sure it's either starter or ignition related but I suppose it could be some kind of relay. Any help would be apreciated, thanks.
Old Jan 20, 2010 | 01:06 AM
12v rollincole's Avatar
If the starter turns over sometimes then just clicks others then its most likly the solenoid contacts in the starter. Mine went bad earlyer this year and it did the same thing, its a cheap/easy fix. there are many places to buy, just an example of the parts.
http://www.puredieselpower.com/catal...it-p-2831.html
Old Jan 20, 2010 | 10:10 AM
infidel's Avatar
Way to test if it's wiring key switch or starter is when it's acting up the put the truck in N, key on, crawl under and short the large and small starter connectors together.
If it starts your starter might be fine.
I buy contacts here, heavier duty than the ones you get elsewhere http://www.fostertruck.com/dodge/default.htm
Old Jan 20, 2010 | 11:14 AM
Dr. Evil's Avatar
If you are buying from Larry B - pick up this:
http://startercontacts.com/relay.htm
and this as well and all will be good:
http://www.fostertruck.com/sol-saverdiode.htm
Old Jan 20, 2010 | 11:24 AM
~Angry Tractor~'s Avatar
Bad battery cables can show themselves in odd ways. You might want to check them, if your starter is good.
Old Jan 21, 2010 | 09:52 AM
leftfield's Avatar
Thanks guys i'll let you know the outcome.
Old Feb 20, 2010 | 11:23 PM
leftfield's Avatar
Well it was definatly the starter, it looked pretty bad inside. I did order the contact kit but then the starter packed it in and I had to buy a new one. It works great (bosch). I might try to fix my old starter or just keep them for the bosch. Thanks for the help.
FMB
Nov 14, 2010 09:09 PM
12valvesmoke
Jun 12, 2009 09:46 AM
buckman361
Nov 13, 2008 09:54 AM
Paradise Racing
Jan 18, 2005 09:08 AM
D4Fritz
Mar 16, 2003 03:55 PM
