Speedometer to wheel size
Got a 96 2500 automatic. I am going from stock 16" tires to stock, off a 2012, 17" tire, I think my speedometer will be off some. Can any one suggest a speedometer gear that might get me close to an accurate reading?
Thanks
Floyd
Thanks
Floyd
It is not the rim size that changes the speedo, but the actual tire size.
Unless you are changing it a lot, say 30 inch stocker to a 35 inch tire, the amount off will be pretty minimal.
How much bigger is a stock '12 tire to a stock '96 tire. An inch maybe?
What do the two tires look like next to each other on the floor? Is one a lot taller? I doubt there is much difference.
Just for grins, i went from the stock 245-75-16 to a 235-80-16, gained about 1-1/2" taller, at 60 MPH the change was slightly less than 2 MPH, so indicated 60 is actually 62.
You would have to really get different for it to matter much.
Like I said unless it is a big change in tire size it is not worth a speedo gear change.
I have ~31's on my 2nd gen, and the MPH is off by ~7mph,
do I just take it to a tranny shop & have them try different gears, or buy gears & do it myself (in other words, will pulling the speedo gear/cable drain out a ton of tranny fluid out?)
As I recall these trucks have electronic speed sensors so a gear isn't used anyway.
Look up new vs old tire diameters and see what the difference is.
I also went to 235/85 tires and my speedometer is more accurate on my "95.
On truly electric speedo tcases, the pickup is aimed directly at the output shaft (not tangential as with mechanical) to read the toothed reluctor ring.
I believe later trucks dropped the tcase speedo completely... sharing the ABS signal off the rear axle.
On your 2006 it it all programming, dealership should be able to accommodate you or I know some programmers do have the ability to adjust, but which specific models are able to I don't know.
EdmontonCanada
10-01-2014 11:55 AM
dr450r
10-17-2012 11:34 AM
bigdogtruck
18
11-21-2007 08:09 PM
