Speedometer to wheel size
Old 05-07-2017, 09:40 PM
blackimpala's Avatar
Got a 96 2500 automatic. I am going from stock 16" tires to stock, off a 2012, 17" tire, I think my speedometer will be off some. Can any one suggest a speedometer gear that might get me close to an accurate reading?
Thanks
Floyd
Old 05-08-2017, 10:22 AM
Received 2,392 Likes on 1,576 Posts
It is not the rim size that changes the speedo, but the actual tire size.
Unless you are changing it a lot, say 30 inch stocker to a 35 inch tire, the amount off will be pretty minimal.
Old 05-08-2017, 08:22 PM
I understand that it's the od of the tire that changes speedometer reading. When I said stock, I meant the stock wheel size. Sorry for the misunderstanding.
Old 05-08-2017, 08:46 PM
How much bigger is a stock '12 tire to a stock '96 tire. An inch maybe?
What do the two tires look like next to each other on the floor? Is one a lot taller? I doubt there is much difference.
Old 05-09-2017, 02:23 PM
u2slow's Avatar
On most Dodges I've owned the speedo reads high in the first place. Going up a tire size makes it more accurate.
Old 05-09-2017, 05:52 PM
patdaly's Avatar
Just for grins, i went from the stock 245-75-16 to a 235-80-16, gained about 1-1/2" taller, at 60 MPH the change was slightly less than 2 MPH, so indicated 60 is actually 62.
You would have to really get different for it to matter much.
Old 05-09-2017, 05:58 PM
Like I said unless it is a big change in tire size it is not worth a speedo gear change.
Old 05-10-2017, 08:58 AM
Thanks for all the reply's. Sounds like there will be no need to adjust for the different tire size.
Old 04-12-2018, 05:50 PM
04ctd's Avatar
I have ~31's on my 2nd gen, and the MPH is off by ~7mph,
do I just take it to a tranny shop & have them try different gears, or buy gears & do it myself (in other words, will pulling the speedo gear/cable drain out a ton of tranny fluid out?)
Old 04-21-2018, 11:52 AM
Ronco95's Avatar
As I recall these trucks have electronic speed sensors so a gear isn't used anyway.
Look up new vs old tire diameters and see what the difference is.
I also went to 235/85 tires and my speedometer is more accurate on my "95.
Old 04-21-2018, 12:13 PM
u2slow's Avatar
On the 94-95 tcases I have... the 'widget' (lets call it) coverts the mechanical gear speed into a electrical signal.
On truly electric speedo tcases, the pickup is aimed directly at the output shaft (not tangential as with mechanical) to read the toothed reluctor ring.
I believe later trucks dropped the tcase speedo completely... sharing the ABS signal off the rear axle.
Old 04-23-2018, 10:02 AM
patdaly's Avatar
On your 2006 it it all programming, dealership should be able to accommodate you or I know some programmers do have the ability to adjust, but which specific models are able to I don't know.
EdmontonCanada
10-01-2014 11:55 AM
dr450r
10-17-2012 11:34 AM
bigdogtruck
18
11-21-2007 08:09 PM
ValkSmile
01-23-2007 11:42 AM
Quick Reply: Speedometer to wheel size
