Six Speed Conversion
Old Dec 9, 2003 | 02:15 PM
BBWD's Avatar
Re:Six Speed Conversion
[quote author=98rammer link=board=16;threadid=23371;start=0#msg220917
most don't seem to hold up well to higher hp trucks, especially the gear vendors.
98rammer:
I have had one in my truck for 100K miles with no problem. The factory says they are good for up to 1100 ft. lbs torque.
IMO they are a pretty good product.
John (DH)
Old Dec 9, 2003 | 02:38 PM
MCummings's Avatar
An Exhaust brake will ruin the Gear Vendors OD in short time.
A U.S. Gear OD would be much better for Exhaust brake use, as the Gear Vendors is just a miniature auto tranny.
Neither the U.S. Gear, or Gear Vendors is a gear slitter. It is only an O.D.
You cannot make your 5-speed a 10-speed with these units.
Last I heard U.S. Gear is working on the proper ratio to make it a gear splitter, and O.D. instead of just an O.D.
Merrick
Old Dec 11, 2003 | 11:33 PM
Suburbanite's Avatar
Muted User
[quote author=MCummings link=board=16;threadid=23371;start=15#msg220930 date=1071002303]...cut... Neither the U.S. Gear, or Gear Vendors is a gear slitter. It is only an O.D.
...cut...
Merrick
[/quote]
AFAIK, that's only true for the USG. My GV, & AFAIK, all other GV's are splitters. That's why you'll often see *pick-a-gear*-OVER in discussions of the GV.
One other drawback (if you can call it that -- not for me) is the fact that it's mounted AFTER the xfr case so can't be used in 4WD. Non-issue for my use. OTOH, the USG is mntd btwn the xfr case & tranny so CAN be used in 4WD.
Old Dec 12, 2003 | 07:43 AM
Watch This's Avatar
im not interested in the overdrive....im wanting the six speed because of the bigger input shaft so we dont have to put the big input shaft in a 4500.
still havent found one though.....
1workinman
Dec 13, 2009 09:18 PM
PITBULL
Jan 20, 2005 09:18 PM
RacerX
Apr 13, 2003 02:07 PM
prairieguy
Feb 24, 2003 02:07 PM
