silencer ring
keep trying, i got mine out after about 1000 tries. i used a small pocket screwdriver under the beveled end of the lock ring and then got another screwdriver under it and it shot out over my right shoulder.
According to Holset, it's an inlet baffle. I used to think it was simply to reduce sound, but since I've seen it on bigger holsets (HX40s, 50s, 55s) I believe it actually smooths out the flow into the compressor. More laminar flow should increase compressor efficiency.
But I still run without one
The silencer ring can also (I've heard) inhibit flow from the MWE on turbos with small exhaust housings.
Apparently I've removed too many C-clips growing up on the farm cause that was a piece of cake. Took me longer to get the intake tube off. I didn't notice all that much difference except that I can hear the turbo spool earlier and I lost some of the turbo whistle. I'll probably be used to it by the time I make the drive to skool tomorrow...
RonP
Feb 17, 2010 09:30 AM
RRC
May 13, 2007 11:45 PM
