Sealing NV4500
Remove the 4 bolts and put pressure on the input so that it dose not come out and remove the retainer. If the input slides out you can drop the bearings between the input and main down in the case. Once you have it off you can remove the seal and replace it with Federal Mogul part # 714655 and then reinstall with a little sealer on the tranny and on the bolts. Make sure that the hole on the back of the retainer is to the top ot the bearing will not get any oil. Lots of work to get to a 2 min fix. It can be done with the bell on the trans.
firestorm
Jun 16, 2005 08:09 PM
hotdram
Mar 3, 2005 06:04 PM
justinp20012500
Oct 11, 2004 06:03 PM
Commatoze
Oct 7, 2003 11:57 AM
