-   12 Valve Engine and Drivetrain (https://www.dieseltruckresource.com/forums/12-valve-engine-drivetrain-100/)
-   -   Replacing fuel lines on 98 (https://www.dieseltruckresource.com/forums/12-valve-engine-drivetrain-100/replacing-fuel-lines-98-a-93139/)
johnstra Feb 21, 2006 10:55 AM
I want to replace the fuel lines on my 98 - the flexibles lines that go from the the steel supply/return to the lift pump and hard line from OF valve. These are not rubber, they are quick-disconnect type lines that are semi-rigid. Who has replace these? Did you just pull them off and replace them with good diesel rated lines?
Thanks,
-john
DZLPWR Feb 21, 2006 11:51 AM
Yep those lines are quick disconnect, but never work. Mine were rusted/fused to the steel lines making it a pita to get off. They will come off though, i just destroyed them with some pilers (dont deform the steel line!!!) and used a twisting motion to get them off. Slip some diesel rated line on the steel line with a hose clamp or 2 and your good to go.
